lt1-ls1 swap
Old 09-03-2008, 12:08 PM
LT1RUNNER's Avatar
Default RE: lt1-ls1 swap
You are talking about a lot of work with the swap. You already have a good starting point with the LT1 so why not just build up on that? No need to search all over trying to find a good deal on the LS1. Besides the LS1 you're going to get from ebay is a used LS1 therefore you may not know how hard that engine was used and could be getting an engine that's on it's last leg. Building up the LT you already have will bring that engine back to when it was new with added power for a little more. Just my 2 cents.
Old 09-03-2008, 12:29 PM
importmd's Avatar
[blockquote]quote:[/i]ORIGINAL: importmd best be would be to get a 98+ front clip [/blockquote]
...............front clip meaning like a cowl cut, the front half of the car. not changing the sheet metal.
Old 09-04-2008, 01:37 AM
95slvrZ28's Avatar
The LS1 is a taller motor as well, so you'll probably have to get a new hood.
Old 09-04-2008, 10:59 AM
1hottcamaro's Avatar
ORIGINAL: 95slvrZ28
An ls1 will fit under an lt1 hood without a problem with an LT1 CAI.
To run the ls1 lid, the radiator has to be tilted back slightly and I am pretty sure a hood like an ultraZ, LT1 WS6, or a cowl will be needed to clear the lid.
Old 09-05-2008, 09:03 AM
importmd's Avatar
slvr...they both sit below the strut towers, you dont need to change the hood.
Old 09-05-2008, 03:21 PM
95slvrZ28's Avatar
The back of the hood isn't the issue, the front would be the problem area.
Thanks for the info 1hottcamaro.
Old 09-14-2008, 01:29 PM
importmd's Avatar
the engine clears just fine, only problem is running the ls1 lid. just run a different air intake, or..
http://www.lt1engine.com/tech/ls1-li...k-camaro-hood/
Old 09-14-2008, 03:39 PM
98ss4REAL's Avatar
sell the lt1, buy a ls1. heads/cam/spray (with a high shot of spray you can reach over 400rwhp with out puting heads/cam)you will have over 400 at the wheels. screw all the hard work to save the 95. it will be cheaper/easier/etc to sell and buy another car.
Old 09-23-2008, 02:29 PM
MAX AMX's Avatar
Are there any issues with LT1 VS LS1 gauges. Will the gauges in an LT1 car work properly with the LS1?
Max
3800_seriesII
08-14-2012 07:24 AM
9434V6
09-08-2011 11:51 AM
xXChipXx
08-01-2010 10:39 PM
miclo88
10-15-2009 07:38 PM
85z285.0
06-02-2007 03:19 PM
Quick Reply: lt1-ls1 swap
