LT 1 strikes again!
Old Jul 7, 2022 | 03:33 PM
I think it would be worth it to find a tech with a scope. If he knows how to use it then there will be no guessing. Electrical , rich or lean misses all look very different on a scope. You can even see for sure if the Opti spark is acting up.
Old Jul 7, 2022 | 08:25 PM
Originally Posted by SleepinZ
I'm definitely starting to think that there is something with the ignition. It will idle, but backfires and cuts out at part throttle, but wide open there are no issues.
The '93 Z28 I had did that when the alternator was going out,drove me crazy for a while then it died completely and quit charging.
Old Jul 7, 2022 | 10:12 PM
SleepinZ's Avatar
I'm definitely going to have it towed and looked at. My pops could read a scope like nobodies business, but he's busy with retirement life, and i don't blame him! 🤣 I will definitely keep this post updated with the conclusion( as long as I'm not bankrupt)!
Old Jul 8, 2022 | 07:38 AM
Just a FYI, you can buy a scope that plugs in to a PC/laptop for cheap. Search Amazon for Hantek they are around $100 and you can get an inductive pickup used for secondary ignition for $20. In theory you could see youtube on how to hook it up then just send screen captures to your dad.
I am one of those old timers myself and I have the Hantek 8 channel with most of the accessories, I also have old school 2 channel scope from the 70's, Frist thing I did with the Hantek was check accuracy with a wave signal and it was spot on.
Old Jul 8, 2022 | 09:02 AM
Corey Jordan's Avatar
Could be the valve stem seals. I installed new ones incorrectly during an overhaul and had horrible backfire on accel and decel. The oil was basically free flowing past the valves. But this is happened a 3.4 v6
sgtdupree
Mar 13, 2011 02:45 PM
White94Z28
Mar 15, 2010 12:09 AM
skulz94
Apr 23, 2008 02:18 PM
Flyin89
Apr 19, 2007 01:40 AM
Camaro_Z28
May 12, 2006 09:10 PM
