Ls1 tick?
Old Apr 24, 2013 | 03:04 PM
djsquare1's Avatar
Default Ls1 tick?
I notice a quiet tick relative to the engine speed. I do have a random multiple cylinder misfire which could be associated with the cause.
It's most noticable when I am in between vehicles or near a wall at idle.
I can't really hear it when I rev it or when I open the hood.
It is also most noticable under the vehicle. I did just do I clutch change but don't think it has anything to do with that as I could hear this before.
Any guesses?
Old Apr 24, 2013 | 03:54 PM
libertyforall1776's Avatar
If happening just when it is cold and goes away when it warms-up, that is "normal", see:
GM Piston Slap -- Like a Knock
Regardless, be sure you are checking your oil level at least every 2nd week...
Old Apr 25, 2013 | 07:54 AM
2Z's's Avatar
Maybe you have an exhaust leak. its possible since you removed the exhaust to do the clutch right?
Old Apr 25, 2013 | 05:30 PM
^^^ or injector click. is it a fast tick at idle or slow
Old Apr 28, 2013 | 01:47 PM
djsquare1's Avatar
Here is a link to the video I took the other day (see below). I just replaced my plugs that day and it made no difference. It happens warm or cold, it's consistent with the engine speed. I have a mechanics stethoscope and I can hear the injectors clicking properly. It sounds like it's coming from under the engine, but I have not pin pointed the sound yet.
https://www.dropbox.com/s/h4e4p5zuvg...04.mp4?v=0rc-s
Old Apr 28, 2013 | 09:07 PM
my first thought was exhaust leak. after hearing a couple times it sounds like a lifter. lol. being its coming from the bottom i would say exhaust leak.
Old Apr 28, 2013 | 09:19 PM
Maybe if you didn't stand the car on end it would idle better. Does sound like an exhaust leak to me too.
TheArtfulLodger
Apr 7, 2012 02:56 PM
6.5 Detroit TD
Sep 9, 2010 05:42 AM
shawnz_90
Apr 17, 2009 09:49 AM
creck
67-69 V8 Tech
Mar 18, 2008 06:55 PM
joeyninetoes
Sep 16, 2007 06:06 PM
