LS1 5qts of oil or 5.5
Weather this has been talked about before or not im going to ask it in my own way. When I change the oil in my 98 ls1 I put 5qts in and its always Full. Now people tell me I should use 5.5 but it always fills up at 5. So what should I do? I don't wanna add to much
it takes a half a quart to fill the filter, when you start it it fills the filter and any jornals that have drained when you took the old filter off. i fill the filter before installing if i can with out spilling, cuts any time the motor is running without oil. yes you do not want to over fill the oil. if it reads full its full. lol.
