Lowering vehicle with driveshaft and torque arm disconnected
Old Nov 4, 2019 | 10:29 PM
JustRebuilt's Avatar
Default Lowering vehicle with driveshaft and torque arm disconnected
I have a 99 camaro 3.8 I have the transmission removed but not enough room to pull it out from underneath the car. The car is sitting on four 4 ton jackstands (extended all the way). My issue being that the car is too high as of right now so its sketchy to lift just the front more, I thinks it might slide off the back stands. I have 2 ramps. So is it safe to lower the rear end onto the ramps with the driveshaft and torque arm disconnected so I can lift the front to gain clearance?
JustRebuilt
Nov 6, 2019 11:23 PM
JustRebuilt
Nov 4, 2019 10:34 PM
91camaro350
82-92 V8 Tech
Aug 3, 2010 07:52 AM
clyon
May 2, 2009 04:13 PM
clyon
May 1, 2009 09:24 PM
