loud noise (bang) from under the arm rest when i accelerate !!!!
Ok guys, i need your help please, i hear a "bang" noise and a slight vibration every time i accelerate hard, it dosent do it when i take off slow, its underneath the arm rest i feel it, what did i do now? is it my tranny ? please help ...
I had the same problem (twice) with mine...
What it is is the torque arm is jumping up and hitting the floor, its that long bar that runs alongside the driveshaft. The top bolt in the front mount came out and when the driveshaft spins it pulls that arm up and smacks against the floor of the car. You can fix it for maybe 50 cents but its a ***** to get to...I just took it to a garage they charged me 10 bucks...its worth it to save yourself the trouble...
I have a 3.4 with a 5 spd so I dont know if the bolts would be the same size but it was 10mm with a 1.5 thread pitch and its about 2 inches long
and I strongly suggest a lock-washer
My 98 Did the same thing, But the rubber tore apart rather than any bolt issuses. Had to replace it 3 Times, Try to avoid cheap Auto-Zone Replacements, Maybe NAPA or something, It sucks to have to re do.
Thanks guys very much for your input, yes it was my tranny mount like most of u mentioned, i just came back from a tranny shop and they replaced it, told me it was torn in half, i feel much better now, it wasnt that expensive to fix, it was like 140 bucks...
Glad that your all fixed up. Did they give you a warranty?
I've had the mount tear apart on me before, and the lifting force from the torque arm was making the tail of the trans smack the tunnel. It happens if you like to be ruff with your stuff! If you eat up another stock rubber mount, you'll probably want to consider using a urethane one.
