lookin for some info on prob
Old Aug 22, 2008 | 08:47 PM
anewgenre's Avatar
Default lookin for some info on prob
i recently purchased a 1996 RS camaro automatic that needs work but being that its a camaro i obviously have acclerated quickly at green lights etc. I notice when i step on the gas to hard n quickly (pedal to the medal) the engine seems to stall/rev put around when i reach 40ish miles per hour, i wonder whats the cause of it, is it the transmission? do i need a new one? or is it something else? it runs fine when i drive normal by the way. Any clear information is welcome.
Old Aug 23, 2008 | 02:04 AM
95slvrZ28's Avatar
Default RE: lookin for some info on prob
If all is well when you're driving normally I woudln't think it would be the tranny. Sounds like it could be an issue with the higher RPM. You may want to do a general tune up (Plugs, wires, fuel filter, change fluids etc.) and check your fuel pump to make sure it's operating correctly.
Old Aug 25, 2008 | 12:52 PM
anewgenre's Avatar
thank you for your reply, your probably right i do have lots to change on the car in due time, i will see if it continues the problem after the tune up/changes
Old Aug 25, 2008 | 06:12 PM
02StanGT's Avatar
Does it hit the rev limiter? See if this helps...
https://camaroforums.com/m_234006/tm.htm
BAdassR/T
May 26, 2009 06:09 PM
bassmaster281
Apr 18, 2008 03:57 PM
gozzy341
Apr 27, 2007 06:18 PM
jrodcamaro
Feb 4, 2007 10:00 PM
