Long tube and ac clearance issues
Old 08-25-2017, 08:30 PM
myslo50's Avatar
Default Long tube and ac clearance issues
Was hoping to get my motor back in this weekend but ran into an issue. Was putting the new headers on and the one primary tube was hitting the ac line and wasn't allowing the header to sit flush with the head. I bent it a little out of the way and the header mounts on the head perfect but now there's like an 1/8" clearance between the header and the ac line. There's not much more room I can get if I keep bending the pipe.
My dad suggested on having a section of the ac line removed and welded back together. But I don't know if that will work.
Any suggestions? Or will it be ok as it sets
I have a pic to post
Old 08-25-2017, 08:36 PM
myslo50's Avatar
[img]webkit-fake-url://b62dbf63-acbc-417b-9d3b-b3e25fe562a4/imagejpeg[/img]
Old 08-25-2017, 08:37 PM
myslo50's Avatar
[img]webkit-fake-url://f7e9bba3-2d3f-454d-9d92-e0959545df11/imagejpeg[/img]
Old 08-25-2017, 08:40 PM
myslo50's Avatar
Wtf. So apparently I can't post a pic
Old 08-25-2017, 08:49 PM
myslo50's Avatar
Try this
Old 08-28-2017, 09:10 AM
i have just enough room to get the end of my finger in between.
Old 08-31-2017, 08:42 PM
MKCoconuts's Avatar
I'd say you're alright but I don't know as I deleted A/C right off the bat.
Old 09-01-2017, 09:38 AM
Zspoiler's Avatar
If you are worried about it make some sort of heat shield. Or use some thermo sleeve.
Old 09-01-2017, 12:54 PM
95 camaro 406's Avatar
steering side should be closer like touching mine was ,but it fits with like said finger on that side too,though i dont hear wich engine your doing in this thread also did Ac delete for the right reasons though i could put it back in at the bottom left side
Chevra
04-04-2012 11:59 PM
rsh3429
04-04-2009 11:12 PM
jbe123
09-07-2007 12:40 AM
Saint_Ali
08-16-2006 05:00 PM
whiteZ28
04-28-2005 05:51 AM
Quick Reply: Long tube and ac clearance issues
