Left turn signal wont signal
I was about to ask the question about the turn signal not working myself.... the left one stopped working about two weeks ago and then last week my right stopped working. I put all new bulbs in on both side's and in the side markers. There are still not working... The hazards are working great. And the ground it great. Do you think it maybe the flasher that has when out of it?
^ When you put new bulbs in, you should try to clean the contacts of the socket if possible, especially if it looks funky -- corroded contacts will do you no favors. Also always use a little dielectric grease on the metal contacts to help prevent corrosion.
