Key Question
Old Nov 11, 2011 | 05:59 PM
Barkat's Avatar
Default Key Question
I had trouble about a year ago with the car not starting. From reading and searching on here, I figured out that the key and/or the key switch was bad. So, I went and got a new one but got lazy. Instead of actually installing it, I just unpluged thew old one and plugged in the new one, stuck the new key into the new switch, and tucked it in up under the dash. Works great! Well, I went to get a new key made for the old switch so I would have a spare, but I just got a regular key made, without the resistor. Because the key switch that I use isnt reading the resistor anyway. But now Ive been through three keys and cant get any of them to work. I dont understand why if the switch isnt reading the resistor, why it would need to even have the resistor in it? Any ideas?
Old Nov 12, 2011 | 10:27 AM
you have two parts to the vats system. one in the columm and one in the computer, im thinking one key was keeping one happy and the other key is keeping the other happy. find out the ohms on the old key and get a blank with the same. number 25 and 26 on the list 4th Gen LT1 F-Body Tech Aids
Old Nov 12, 2011 | 11:10 AM
Barkat's Avatar
I'm sorry, I should have explained it better. I had a new key made for the old tumbler, without the resistor. The problem is that i can't even get the tumbler to move. It may start the car, if I could get it to move. I'm thinking that the resistor wouldn't have anything to do with that, right? It acts like it's cut wrong. But like I say, I've had three cut now.
Old Nov 12, 2011 | 10:05 PM
thats strange, should not matter if the bean is there or not.
Old Nov 13, 2011 | 03:44 PM
Barkat's Avatar
Well, that's what I was thinking too. Just thought that maybe there was something I didn't know about?
Old Nov 13, 2011 | 08:00 PM
shawnathan's Avatar
Sometimes the new keys edges are just too sharp and don't move the tumblers correctly try simulating wear with some sand paper and see if that works
Old Nov 14, 2011 | 04:53 AM
Barkat's Avatar
I was just sitting here thinking the same thing. I'm also thinking maybe hit the new key with a wire wheel? Not sure if that would dull the teeth up or not.
Old Nov 30, 2011 | 12:47 PM
aquariussuperman's Avatar
So if the correct resistor bypass is installed in the column, you shouldn't need a key with the pellet correct? The computer will just be fooled and not light up the SECURITY light? Thanks.
Old Nov 30, 2011 | 01:54 PM
iLL95's Avatar
I Like to Party
Super Member
That is correct..
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
