just changed waterpump, rpms are high now??
Old 06-10-2012, 10:19 AM
auto's Avatar
the only vaccum i unplugged was the one to the throttle body and left the plugs in. i notice when i turn the throttle(where the cable is) on the throttle body away ( to the front of the car) the car idles correctly, but then if i rev it on the gas pedal, it doesnt go back to that position
Old 06-10-2012, 10:53 AM
check the cable to make sure its not binding, that is if you have a cable. make sure the gasket is not hitting against the tb butterflies and holding it from closing.
Old 06-10-2012, 03:29 PM
auto's Avatar
loosed the tb, gasket wasnt in the way, re tightened the tb evenly then 1/4 turned them, and now back to normal, everything was plugged in, didnt see much bubbles from the rad cap after the waterpump, is that normal? car hasnt overheated
Old 06-10-2012, 08:08 PM
dlaidoutranger's Avatar
Also does anyone have experience with falken tires or even falken tires one 4th gens?[/quote]
i havent had them on a fourth gen but i have run them on a built dodge neon, (no laughs, i was making 325hp to the front wheels) they are great tires they just dont last long, i couldnt get much over a years use out of them, but they are great while they last
Old 06-10-2012, 11:52 PM
this is a 3.8 right? i dont think 3.8 has or needs bleeders. look for the high point in the cooling system and see if theres a plug or valve. my truck just has a plug to take lose. anyways you can also park on a incline with the up side to the front of the car to help any air to move to the top of the radiator.
Old 06-11-2012, 10:48 AM
auto's Avatar
mine is a 5.7 , i let the car run with the cap off, saw some bubbles and when it started to run over i capped it. drove it out of hell last night and didnt over heat, seems okay, i noticed that the car doesnt have that little stumble anymore on take offs, could that waterpump pulley been that bad?
Wayne350
03-13-2012 07:57 AM
Katzen
10-19-2011 12:21 PM
BasicConcepts
05-20-2011 05:21 PM
Billy
09-07-2007 04:42 PM
amers041
07-09-2005 12:49 AM
Quick Reply: just changed waterpump, rpms are high now??
