Jack from harmonic bal. pulley? or from oil pan?
Old Sep 16, 2010 | 09:11 AM
auto's Avatar
Default Jack from harmonic bal. pulley? or from oil pan?
just ordered poly mounts, got a friend with a lift, any surprises i should know before hand? and which should i jack from? 69? gorn? maudy? anyone! thx!
Old Sep 16, 2010 | 10:32 AM
NEVER jack from the harmonic damper, that's not good for the crankshaft. Throw a 2x4 or 2x6 scrap piece of wood on top of the jack to spread the load, and span it across the oil pan to lift the engine.
Old Sep 16, 2010 | 10:45 AM
I like to stand a 2X4 or 2x2 up and reach up into the motor mount/head area. Pan is a bad idea cause it could cause a leak now by over compressing a dry gasket/seal or if you ever have to reseal it a small twist from stress means it will never seal again. Like Camaro 69 said Vibration damper is a huge no no. The car has no oil pressure while it is not running you could damage the front main bearing and wipe out the whole motor.
Old Sep 16, 2010 | 11:02 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You mentioned a lift... what kind of lift?
Old Sep 16, 2010 | 11:14 AM
1augapfel's Avatar
^+1
Never, never, never *ever* lift the motor by pushing up on the harmonic balancer.
Oil pan isn't ideal but will probably be okay *if* you place a 6"x6" board under the pan where you will be placing the jack, stand, or whatever.
V6 or V8?
When you say that you got the poly mounts are you talking about the ones that you install in your existing mount shell? If so, where are you getting them? Be sure to report on how they work for you because I'm thinking of going that route.
Old Sep 16, 2010 | 12:23 PM
auto's Avatar
o man thank goodness i didnt listen to that bum who said jack from the balancer. i got a v8 1augapfel.
are there any other options other than from the oil pan?, cuz i dont think that pan was ever dropped.
the lift is a garage lift, 4 arms go under the car and lifts it bout 6ft in the air. im anxious to feel how that baby is gunna run after... i just did 1000 miles since getting it, its been a year already :/
Old Sep 16, 2010 | 12:25 PM
auto's Avatar
this is what i bought
http://cgi.ebay.com/ebaymotors/Proth...Q5fAccessories
instead of a 6x6 wood, how about a phone book? if its paper it would take some of the stress?
Old Sep 16, 2010 | 01:25 PM
greenarrow's Avatar
September 2009 ROTM
I had to sand away some of the material around the bolt holes holding it into the crossmember because it stuck out to far and was preventing me from getting the bolts in there with them sitting on the crossmember. Just something to look at before you get them in there and you have to pull them out.
Old Sep 16, 2010 | 02:06 PM
rent or buy a engine lift from autozone. or is there something to hook into above the car.
Old Sep 16, 2010 | 07:01 PM
auto's Avatar
nope nothing to hook from the top.. that brand is decent enough though right? n thanx every1 for the input
