Intermittent Trouble Starting
Thanks for all the input! Thought I would post here with an update. Computer system is free of trouble codes. Fuel pressure gauge indicates pressure is good. Replaced the fuel pump relay, but the problem still persists. My next move is to replace the plugs/wires. Will post more updates when I have them... Thanks again!
woh,,, no codes. that makes it a little harder to find the gremlin. quality plugs and plug wires would be a good start. a failing injector can cause issue that comes and goes but is unusual. test the evap system to make sure its not hiding there.
