interior water leak
Old Jul 17, 2015 | 01:35 PM
tampatony's Avatar
Default interior water leak
2001 3.8......I recently developed a water leak that shows on the floor on the drivers side.
Is this something that is common?
Can it be from the ventilation system whereby the vent door, that allows outside air to enter, is not closed properly? Thanks.
Old Jul 17, 2015 | 08:32 PM
95 camaro 406's Avatar
not com.mon that I know of ,you don't mention t tops or not,could be hard driving rain.seals on the door ,only time I had .water on my floor in front was a heater core leak,could be .the drain line from the AC ,give more information
Old Jul 17, 2015 | 10:16 PM
J-Factor's Avatar
Location of the leak on the driver floorboard would help. Is it constantly there or only during wet weather?
Old Jul 18, 2015 | 11:31 AM
unusual for water to get on driver side. i would think door seal, windshield or t top if you have them. front or rear?
Old Jul 20, 2015 | 08:14 AM
tampatony's Avatar
Water shows front driver side, no t-top. Appears after rain. I read on another site that it may be clogged drains in the fresh air vent area. Is it difficult to remove the cowling to inspect that area? I tested by running water over the area and pulling back the carpet but I did not see where it entered.
Old Jul 20, 2015 | 09:22 AM
have a look under the car and see if you have any holes or drain plugs that have been removed in that part of the floor. only thing i can think of is the door/window seal. or maybe one of these cans is disfunctioning laying open under the seat
Old Jul 20, 2015 | 09:45 AM
there is a spot behind the wiper motor that could be leaking also the steering column seal may be the issue.
Old Jul 20, 2015 | 09:51 AM
here is a thread for older 4th gens wiper motor info. https://camaroforums.com/forum/93-02...rmation-66130/ you should go ahead and download the factory manual for your year here, click the 2000 svcman file, it will be same as yours https://www.mediafire.com/?40mfgeoe4ctti
Old Jul 20, 2015 | 11:19 AM
tampatony's Avatar
Thanks for the input Craby. I can rule out the can as being the source since that's not my drink of choice. I like the clear stuff with a little OJ! I have a look underneath and let you know.
Massey
Jul 18, 2011 06:58 PM
montecarlogrrl
Apr 13, 2011 07:30 PM
94z28red
Mar 20, 2011 08:49 PM
Massey
Nov 4, 2010 10:44 PM
94camaro3.4
Jan 19, 2008 03:48 PM
