Intake Manifold Porting
dont go to audiforums....... a kid there blasted sand through his while it was still on his car [&:]
is this a normal mod? i was under the impression that the lt1 manifold is pretty good the way it is, which means u wont see any gains because u arent attacking a restriction point
yeah now that i look into it more theirs no power gains in it. i just dont really know what mod to go for next. i think im going to get a cutout, let me know what else you think i should do (mods are in my sig)
Maybe you can go with suspension mods. It does no good to have all that power if you can't put it on the ground. This is a very common mistake and we all feel that if we get 1000hp then we can beat anyone. That 1000hp will beat no one if you're just spinning wheels. Maybe you can work on that until you can dig into the internals and build a stroker or sc it.
Really the only thing that you can do to the LT1 intake is port match it to aftermarket heads (as already brought up) or you can port out the front to fit a 58mm TB. In the stage you're at, you have bolt-ons finished, so now it's time for heads/cam if you're looking for more power. You're getting into the expensive stage.
ive been planning on a head/cam package for a while or atlest just a cam heads are pretty expensive, but i think im going to wait untill winter to do that so theirs no rush to get it done. i just wanted to see if their were any other things littlei could do before that
