installing radio
Old 01-13-2015 | 07:55 PM
warmeck's Avatar
Default installing radio
does anyone know if this is a plug and play swap from the stock one? i have a 94 lt1 camaro BOSS Audio 612UA In-Dash Single-Din USB/SD/MP3 Player Receiver
Old 01-14-2015 | 07:44 PM
Tipsy's Avatar
BOSS Audio 612UA is an aftermarket radio sold at Walmart and Amazon, etc. It would not be plug and play to your car without an adapter harness. If you are asking if this BOSS Audio 612UA can be removed from your car and a stock radio can be put back that will depend on whether or not a harness adapter was used and the factory harness was not butchered.
Old 01-15-2015 | 02:00 PM
warmeck's Avatar
where can i buy this adapter at and i want to put that boss audo radio into my car and reaplace my stock one. i also dont know the radio code? what should i do about that.
Old 01-15-2015 | 09:44 PM
Tipsy's Avatar
Adapter can be purchased at Walmart sometimes, definitely at Crutchfield.com, Best Buy, etc. Where did you get the Boss radio from? If you are removing the factory radio you don't need a code. It's only for that factory radio.
Old 01-15-2015 | 10:06 PM
warmeck's Avatar
would this work? Scosche Car Stereo Wiring Connector 94-06 GM - Walmart.com
okay thank you i got very confused and thought i needed a code. i cant find a nice step by step guide on how to replace the radio so hopefully its pretty simple.
Old 01-16-2015 | 08:27 AM
Tipsy's Avatar
That's the one! And if you google "step by step guide on how to replace a car stereo" you will find all sorts of information to use! Youtube videos, Crutchfield has info, all sorts of articles. Good luck!
Old 01-17-2015 | 05:54 AM
fbodyrs96's Avatar
If you car had the stock bose system, that harness is not going to run the speakers due to the bose amps.
mr.blue
11-29-2011 12:47 AM
Imperial RS Marty
01-26-2011 08:23 PM
jason7504
11-17-2009 05:27 PM
Saint_Ali
01-24-2007 07:13 PM
72ponyeater
01-16-2007 10:17 PM
