to install t tops
to install t tops
i have a 96 z28 camaro with out t tops but needs trany i am picking up a 95 trans am for $500 with no motor but with $2200 stuck in to the transmission is the main reason i am buying it but the TA has t tops and i was wondering if i could swap roofs to put the t tops on my camaro the TA interior is shot but with a good head liner thats y i ant swapping motors has anyone done this before
I have a '96 Z28 Camaro without t-tops. It needs a transmission, so I am picking up a '95 Trans Am for $500. It has no motor, but the main reason I am buying it is because it has $2200 in the transmission. It has t-tops and I was wondering if I could swap roofs, in order to have t-tops in my Camaro. The Trans Am's interior is shot, but it has good headliner, that's why I'm not swapping motors. Has anyone done this before?
Dont think you can swap out roofs, the t-tops have a welded structure in the centre as you will see on the TA. I presume the camaro has a solid steel roof. I wouldnt like to go cutting the roofs off cars just to swap them.
Sell the t-top glass and make some bucks back
