install 97 camaro rs foglights
so i want to install some foglights because ive seen them on so many other camaros and mine doesnt, but in the past i hooked them up to a switch, so if someone could let me know how to hook em up to turn on when the headlights do thatd be great
Yeah, i do. This is the wiring diagram i found,
http://www.classictruckshop.com/club...h/foglites.htm
but i cant find a fuse for the headlights.
or is there another way of doing it?
have you looked to see if there is wiring harnesses where the driving lights go. im thinking someone didnt like the way they looked and took em off. may just be a matter of mounting them and hooking to the exsisting wiring.
look closely they may be stuffed in a cubby. might have to get under it and take the lower flap on the front bumper cover lose to see them. theres like three plastic push retainers. if nothing else you should be able to get a relay in the fog light relay spot and wire to it. the lights would come on like the driving lights. thats when the switch is on and parking lights are on the fog lights will be on and when the switch is on and the headlights are on dim. if you want them on when you wish them to be you will have to wire them in yourself
