Im lost
Hello guys,i have a 1993 camaro 3.4 v6 with a fresh rebuild of 1,000 miles. It ran well and one day one of the fuel injectors started leaking fuel into my engine and out of the tailpipe. Once i got that figured out i installed new injectors, new 02 sensors,new spark plugs, new wiresnew tps and new iac sensor fired it up and it idled good, put the car in gear and it cut off. Fired it back up n pulled out the driveway n it cut off again. I also have a new fuel pumpand a new fuel pressure regulator. Everything on the car is new and i cant figure this out. Yes, my check engine light did come on but it went off. Once i was able to get it down the road,pulling off from a stop light it may cut off or hesitate when i accelerate and then it will go.anybody know exactly what brand scanner i should buy, i tried the jumper method and that dont work n im tired of giving chevy $130
