ignition control module
What are the signs of a bad ignition control module? Just rebulit a motor and went to fire it and its not firing.
Its a Lt1
Signs of a bad one are it won't start when you turn the key. My expierence has been that when it's going out you have to wiggle the key around to get it to start. Or turn the key several times to get it to finally take.
4 Attachment(s)
check this stuff out and see if it helps. found in the how to and faq sticky and the lt1 section https://camaroforums.com/forum/lt1-l...37/#post579761
Attachment 16350 Attachment 16351 Attachment 16352 Attachment 16353 |
My ICM went out, or was going out and after the car would sit for a few hours it would start, but would die after about 5 minutes and not start up again until it sat for a few hours. I tried everything to get it to start including starting fluid and had no luck. After getting it narrowed down to the ICM and replacing it my car starts and stays running like it should
