Idle slow, Check engine light blinking
Driving fine. Check engine light started blinking. Slowed down to a stop sign, the idle seemed sluggish. I havn't put it on adiagnostic computer yet. Will the computer tell me, via codes, whats wrong with her?
Put it on the diagnostic. Cylinder #4 misfire....... Ciol pack was very corroded on the 1,4, the other two looked fine. Replaced it , Nothing different.... Replaced just the one plug, Nothing Different..... Down to the wire? As a last step? Does any one know how the plug numbers layout on the engine?
#4 Cylinder Misfire
On the machine #4 misfire. Coil Pack was pretty corroded on the #4 and #1 plug. Replaced it .... Nothing Better...
Next changed out the #4 plug.... Nothing Better....
Changed "A" and "C" and not "B".. The wire...
Do you know how the spark plug numbers are layed out on the engine? I just want to make sure they are all on right.
what yr and model? whens the last time u changed plug wires. could be it. as far as i know for a v8 its odd on drivers side 1 3 5 7 front to back, even on the pas side. for a v6 in my 93 book it shows 2 4 6 on the drivers side front to back and odd 1 3 5 on pas side. check #1 plug and wire also. just read again and see u changed it already. try wires.
dealer shop manuals are what ive always used. that way u get all the info for your yr car only. not all the other year stuff that confuses a guy. did a google and got this for your car. couldnt get it to go right so u will have to past onto your address bar.
http://cgi.ebay.com/ebaymotors/1997-...Service-ManualSet_W0QQitemZ250418221800QQcmdZViewItemQQimsxZ2009 0504?IMSfp=TL0905041210005r26763#ht_2286wt_1166
ps i think they changed the fireing order in 97. if not u may have 1 and 4 reversed.
hotrodpuch
11-25-2011 10:08 AM
Nitemare3o5
05-06-2008 07:55 PM
