I pulled battery cable to clear code,oil monitor ?
Old May 7, 2016 | 06:30 AM
80sz's Avatar
Default I pulled battery cable to clear code,oil monitor ?
My car service engine soon light came on. Went up to auto zone,small leak evap. Bought a new gas cap,the old gasket shot,I just swapped gaskets and kept old cap with the retainer. To clear light I pulled the battery cable,all good it's off,but now did I mess up my oil service monitor? I reset it at last oil change ,I'm at 4000 miles on it should be getting close but now I'm worried I reset that also,I wanted to see how far I got ,my cobalt usually went 8,000 miles before a change.
Old May 7, 2016 | 09:05 AM
80sz's Avatar
Prolly fine,the mileage stayed so I issues pose that info is retained also
Old May 8, 2016 | 08:08 AM
did you hold the +&- cables together to do a full reset? i would think it would retain that info if not.
Old May 8, 2016 | 08:28 AM
80sz's Avatar
No,I removed the neg cable only . Holding them together I never heard of that,I guess it would drain it completely? There must be battery for backup somewhere to hold that info.
Old May 8, 2016 | 08:46 AM
when you take both off and hold together for a minute it should clear all computer memories. not sure how, lol.
Old May 8, 2016 | 08:53 PM
GaryDoug's Avatar
The SRS (airbags) computer has large storage capacitors that allow the 12v power to remain on for up to 10 seconds in the event of battery circuit failure during a collision. That affects all modules. But a wait of 30 seconds or more should be adequate to clear the codes. Shorting the battery cables together will speed up that discharge process for the other modules except the SRS.
mike6208
Jan 7, 2012 10:52 AM
MoreLikePALcohol
Sep 12, 2006 09:21 PM
MoreLikePALcohol
carlsbadlt1
Nov 10, 2005 11:35 PM
