i have some questions
Old Oct 1, 2008 | 05:36 PM
meteoralp45's Avatar
Default i have some questions
okie dokie, well i just posted in the o/t about my new ls1 so i have some ?'s
basically i just bought a ls1 block with a crank and main caps and a set of clevite H series rod bearings, the block has just been machined and bored .30 over and i know a guy with some ls2 ported heads from lingenfelter i might get
well first thing. will the ls1 bolt up to the t56 i have now, or are the t56's in the lt's and ls's different?
i plan on having forged internals ready for a s/c later on down the road, any suggestions on brands and where to buy.
and also any other suggestions or help will be greatful.
Old Oct 1, 2008 | 05:53 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: i have some questions
the t56 isnt your problem. I think you may need the 98+ front clip or the motor wont fit or something goofy like that....
Old Oct 1, 2008 | 07:39 PM
95slvrZ28's Avatar
Before Import bites our heads off...
You can fit the motor under the hood, but you need to run the LT1 style intake. If you want to run the regular LS1 'Lid' style intake you need to tilt the radiator back. The T56 you have now won't bolt up directly, it has a different bell housing and a different input shaft.
Old Oct 1, 2008 | 07:56 PM
98ss4REAL's Avatar
might be able to find urself a cheap ls1 roller on racingjunk.com.. u could have a sweet street strip car later down the road...if ya wanna spend a lil more mney that is...
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
