I feel like I am riding on a boat
Old Jun 21, 2010 | 07:25 PM
VF-124's Avatar
Default I feel like I am riding on a boat
1993 6 cy. stock
A little back and fourth on the wheel and I feel like I am riding on a boat
(or one of those old caddys.)
New shocks and sway bar bushings in the front done. Still nothing.,
shuld I try back shocks or springs in the front next?
Old Jun 21, 2010 | 09:33 PM
check and most likely change the outer tierod ends and check the wear idicators on the ball joints. if the base of the grease fitting is even or below the ball joint housing edge thats next to it then its time to change it. what tires are you running, what max air pressure is called for in them and what air pressure is in them. what struts did you get for the front?
Old Jun 22, 2010 | 12:23 PM
As Craby indicated, getting the suspension and steering back to new condition is the best thing you can do to get the car to handle properly. Fancy tires, shocks, etc on a worn out suspension will just amplify handling & ride problem. Ball joints, tie rod ends, control arm bushings (front & rear), sway bar bushings & links, panhard rod, steering rack, all need to be checked out and renewed as needed.
Old Jun 22, 2010 | 04:51 PM
bcartman2's Avatar
like they are saying tie rods and balljoints are a likely culprit,
Old Jun 22, 2010 | 06:02 PM
MTRIMBOLI's Avatar
VF-124, are you stationed there?
Old Jun 27, 2010 | 12:11 PM
VF-124's Avatar
VF-124 San Diego 1984-87
Old Jun 27, 2010 | 11:51 PM
libertyforall1776's Avatar
How many miles on the car?
Z28Freak
Apr 16, 2011 04:24 PM
cruz7o3
Nov 24, 2007 09:09 AM
dmacqrazi
Jul 6, 2007 10:22 PM
Cowboy Joe
Feb 4, 2007 04:15 AM
