How to lift body from k-memeber
Old Oct 16, 2012 | 06:16 PM
|m()d's Avatar
Default How to lift body from k-memeber
ok so i started pulling exhaust manfolds and wow no room to work surprise surprise Im on drivers side and 1 stud on last port is giving me headaches. and when i took off heat shield off on passenger side I noticed a broken stud! So I think it will be alot easier to do the work I want to do to lift the body. I have searched but cant find much Is there a write up on lifting body? I think I read sometime ago that its 8 16mm bolts? Thanks guys anyone in southern Wis that wants to help im buying the beer!!!
Old Oct 16, 2012 | 07:03 PM
BasicConcepts's Avatar
Technical User
Its 6 18mm bolts. Jack up the car and support with stands, than put the jack under the subframe, unbolt the 6 bolts (3 on either side) and lower the jack. You should be able to get the engine down about 8 inches. Also when your lifting the subframe back up make sure the steering shaft is still in place, if you let the subframe down enough it will pop out.
Old Oct 16, 2012 | 07:14 PM
|m()d's Avatar
ok you say jack up car and support where exactally you talkin? On the k member itself? or on the control arms? are the 3 bolts by the strut tower brace? thanks for the help
Old Oct 16, 2012 | 07:17 PM
Technical User
Support the car under the rockers where the pinch is that way if you have to get under the car you can also the subframe will come down farther than your jack with the wheels on the ground.
The bolts ars under the subframe, ill try to find a pic for you.
you gotta go through the hole where the x is with a 10 inch extension
Old Oct 16, 2012 | 07:38 PM
|m()d's Avatar
Man I cant thank you enough!! This pic is perfect thank you
Old Oct 16, 2012 | 07:46 PM
Technical User
No problem man.
Old Oct 17, 2012 | 08:27 PM
jkeaton's Avatar
6 bolts is all that holds the engine in? You take out those and the whole k member/engine will fall out the bottom?
Old Oct 17, 2012 | 08:50 PM
Technical User
ya pretty much, you gotta disconnect the struts, front brake lines, electrical,exhaust and the trans crossmember and the whole engine/trans/front suspension comes out.
jrc209
Feb 7, 2012 06:16 AM
SWT95SS
Feb 19, 2010 10:18 PM
M258
Nov 24, 2009 06:19 PM
johnEB
Sep 2, 2007 02:08 PM
mazdabon2nd
Aug 28, 2007 11:49 AM
