How do I replace wheel bearings?
Old 08-17-2017, 01:27 AM
Black and white's Avatar
Default How do I replace wheel bearings?
So I know how to do my rear bearings, but there's only one problem, my car has drum brakes on the rear. I've also bought new drum brakes and hardware. How exactly do you take the drum brakes off so you can take the axle out? Couldn't find anything online so posted on here looking for some assistance. (I drive 1994 Camaro v6) Any help would be appreciated
Old 08-17-2017, 01:39 AM
right off download the factory service/shop manual for your year.
Old 08-17-2017, 01:41 AM
go here click 94svc file. https://www.mediafire.com/?40mfgeoe4ctti once get used to the way they are written pretty good.
Old 08-17-2017, 01:56 AM
I ordered a bunch of stuff off rock auto including a service manual. But before that and everything else I ordered arrives I'd like to get an idea on how I can take everything apart. The bearing didn't arrive yet, neither did the brake hardware. My factory service manual isn't gonna help.
Old 08-17-2017, 02:04 AM
I found my service manual with that site u gave me. It's a big help thanks.
Old 08-17-2017, 06:51 AM
Check out youtube for videos. Just about all GM Drum brakes are the same even back to the 70's. Most lighter GM rears have the same process for changing the rear wheel bearing. You are going to need a bearing puller.
Maybe you should have waited before you ordered the bearings. If you axle has wear on it you may need offset bearings. GM went the cheap rout and they use the rear axle as the inner bearing race.
aaron_Z28
10-10-2009 12:36 PM
Als95Z28
09-21-2008 01:05 AM
07-01-2008 04:16 PM
z28punkhed
03-24-2008 08:51 PM
Cam Can
11-21-2007 08:54 AM
Quick Reply: How do I replace wheel bearings?
