Houston... We have a problem...
Old 08-26-2007 | 11:48 AM
Default RE: Houston... We have a problem...
Put a socket and ratchet handleon the center bolt on the tensioner pulley, turn clockwise, this pushes the tensioner down and relaeses the belt. Make sure all the pulleys spin easily before putting on new belt, so you don't break another one, especially the alternator and power steering pump.
Old 08-26-2007 | 12:24 PM
Spartan66's Avatar
ok great, so no specail tool like on mustangs?
Old 08-26-2007 | 01:01 PM
No special tools, but watch out for your knuckles, may be a good idea to disconnect the battery so that the fans don't come and grab your fingers. LOL
Old 08-26-2007 | 01:17 PM
Spartan66's Avatar
lol ok. Now my original belt is all tangled and mangled.. so im guessing ill have to cut it out.. but then just loosen the tensioner pulley string the new belt on like the model shows and tighten it back up. Will i kno when its tight enough? do i turn it til it wont turn? Then as far as battery, if my current one doesnt have enough power to start my car, with the alternator will it charge back up? and thanks for your guys help! I was flippin out thinkin i would need a new ps pump.
Old 08-26-2007 | 01:23 PM
02StanGT's Avatar
You don't "loosen" the pulley, but merely push it out of the way. It's spring loaded, it knows when it's tight enough. The alternator doesn't charge the battery back up unless the car is running.
Old 08-26-2007 | 01:24 PM
usarmyrangrs's Avatar
The tensioner is spring loaded, so you don't have to make any adjustments. Simply do as Pete said, and once the belt is in place, let off the tensioner pulley. You're done. The tensioner takes up slack as the belt wears. Make sure the belt is routed correctly!
Old 08-26-2007 | 05:16 PM
Spartan66's Avatar
HA! Got it running! now i just need to take it to get serviced [:@]lol
Old 08-26-2007 | 05:48 PM
02StanGT's Avatar
That's good! Everything running like it should?
Old 08-27-2007 | 03:20 AM
Spartan66's Avatar
yep, battery is good drove it around awhile and its just fine... Now i need to take care of a ticking in my engine [:@]and my oil is low and dirty.. im going to get it lubed 2morrow
  #20
Old 08-27-2007 | 04:47 PM
Spartan66's Avatar
God a full 20 point oil change and inspection today... other than my air filter being full of bugs and dirt and a moderate oil leak im golden.. [&:]
firstbird
07-26-2011 01:33 PM
DeathProof
07-21-2011 02:20 AM
STKSUX
06-18-2011 11:58 PM
MaVeN
Central
08-20-2010 09:01 PM
BumbleBee
07-04-2010 09:11 PM
