horrible mileage
Old 01-20-2011, 07:56 PM
auto's Avatar
Default horrible mileage
the past few tanks of gas i have been getting 120 miles max. since i changed the fuel filter its been doing this, other than that no check lights, no difference in driving and no other changes to the car?
Old 01-20-2011, 08:15 PM
BasicConcepts's Avatar
Technical User
theres gotta be something else going on a fuel filter wouldnt make that happen
Old 01-20-2011, 08:30 PM
auto's Avatar
cant figure it out, no miss in the engine, still burns rubber like no tomorrow, ideas?
Old 01-20-2011, 08:59 PM
auto's Avatar
think i should do basic tune up like pcv, plugs, wires, clean throttle body n MAF???
Old 01-20-2011, 09:00 PM
Technical User
ya just be careful with the maf there pretty expensive
Old 01-21-2011, 05:07 AM
maudyZ28's Avatar
are o2 sensors ok? one of mine 'fell' out once but not fully just so there was a leak upstream of the front o2 on the header. The O2 read low so fuel trims were +20% but one light. I only noticed cause milage was crap on a short 80 mile journey used like half a tank.
my pals GTO headers did the same they were loose so the o2 were irratic but not low enough to cause a signal just change the fuel trims.
Check fuel filter connections again leaks in pipes etc. or try another one.
PS still aint photoed the wingsheild cowl thing, really icy here so can see much other than frost and light dusting of snow
Old 01-21-2011, 11:38 AM
auto's Avatar
its cool, i had gotten one off somebody, i had to take it off his car, so i saw exactly how its supposed to go, its a 1/2 inch depth from the top of the windshield to the frame on the dudes car, havent tooken mine off yet. when u say the 02 walked out was that with stock exhaust manifolds or your headers? think i might try a stealership fuel filter..
whats the story behind some "new" pcv for these cars?
Old 01-21-2011, 12:23 PM
A fuel filter doesn't/can't cause high engine fuel consumption, the injectors meter the final flow. Leave the filter alone, unless it's leaking. Any chance you live in a cold climate, and you've been letting the engine idle more lately to warm it up? Also, in some areas, gas stations sell a "winter blend" of gas that contains a higher percentage of ethanol than what the summer blend has in it. More ethanol = lower mpg's.
Old 01-21-2011, 12:53 PM
auto's Avatar
i live in nyc, but i always let the car run to when the needle starts moving past 100 degrees before i take off, but thats no more than 3-5 mins of idle, the filter isnt leaking too. i guess its possible that they are putting more ethanol, these prix around here take your money any way that they can. i paying $3.69/gal for the camaro gas
auto's Avatar
so frustrated its making my speech go
Quick Reply: horrible mileage
