Hood Bump Stop thingamabobbers...
Old Apr 3, 2013 | 10:36 PM
Dro94Z28's Avatar
Default Hood Bump Stop thingamabobbers...
Yes I said thingamabobber, lol. Both of mine for the hood are broken. These listed here on Ebay don't look like my originals. Is there a better source for these?
93 97 Camaro Z28 Firebird TA Hood Bump Stops Adjust Adjustable Front Set | eBay
Old Apr 3, 2013 | 11:06 PM
Dro94Z28's Avatar
Also if someone could tell me what the red guy in this picture is I would appreciate it.
Old Apr 3, 2013 | 11:29 PM
Camaro/Firebird 93-02 Hood Bumper Stops - Hawks Third Generation
That "red guy" is a power junction block. Those wire connections would likely benefit from a removal, cleaning, and reinstall...be sure to disconnect the positive battery cable first.
Old Apr 3, 2013 | 11:56 PM
Dro94Z28's Avatar
Thank you for the info on these. The junction block no longer sits where it is supposed to. Only has one tab left on the bottom of it. Hoping to find a replacement. Trying to come up with all of my parts before I get started on clean up.
Old Apr 4, 2013 | 12:59 AM
Dro94Z28's Avatar
Any idea if anyone carries the power junction blocks anymore? I've been searching, but haven't had any luck. Found one thread where someone got one, but was a few years ago and no mention of where he got it.
Old Apr 4, 2013 | 06:43 AM
impala765's Avatar
Take a look here but got to be cheaper someware else.
http://gmsportssalvage.com/?q=node/922
Check here #9 on the diagram
http://www.tonkinonlineparts.com/sho...ssembly=858377
Old Apr 4, 2013 | 03:35 PM
Dro94Z28's Avatar
1993-1997 LT1 B+ Junction Box | GM Sports
BATTERY CABLES & MOUNTING. Fits: Camaro, Firebird | Tonkin Online Parts
Thank you for finding this. I found a few places last night, but none had any actual confirmation that it was the part I was looking for aside from text and the part number. I'm always a little leary when I can't see what it is i'm paying for, lol.
Old Apr 5, 2013 | 02:31 AM
Dro94Z28's Avatar
Tried twice to day to order that junction box and both times they didn't have it and said they couldn't get it. Is there a different kind that I can use to replace this one with rather than spend all this effort to find the original? Preferably one that is covered as well.
Old Apr 5, 2013 | 05:57 AM
just gota keep seaching. took me a month to find one. came up on ebabe
Old Apr 5, 2013 | 07:26 AM
You know, there's nothing wrong with your junction block, except for the mounting tabs being snapped off. If it were mine, I would drill a hole above the junction area, and run a self drilling sheet metal screw through it and into the inner fender. Screwed down is how an aftermarket block is going to mount anyway, if that's the route you were to end up taking.
