hit a curb last nite
No prob. I live like 5 minutes away from there, so that was the main reason for going there. Didn't want to risk overheating again and causing even more problems.
I am having cooling problems too and it is about pissing me off, I may be pulling heads [grrr]
OK as for hitting the curb... check out your panhard bar under the car. It is the long bar that goes from the rear end to the passenger's side. It should be U shaped and straight with no bends in it at all. If is bent or the U-channel goes narrower or wider you need to replace it. If you dont your car will run down the road like a dog that is tied to a chain. A bent panhard bar will prevent you from getting a proper alignment. You can get the front end aligned with a 2 way alignment but if you get a 4 way alignment the screen will pop red all over the place. The alignment tech fresh out of high school auto shop will say "sumptins bent...er... " So check everything out and replace anything that is bent before you head out.
Massey
Massey
