hesitation and bad mpgand miss
Old Mar 27, 2012 | 05:02 PM
DemonDark's Avatar
Default hesitation and bad mpgand miss
Hello all again been a long time, but to the point I've searched the forums and for the life of me find out what this rubber T is called i think the leak from itis causing a slight miss and bad mpg along with a few other thing. what i know is after reading some posts is it connects to pcv vlv and evap cnstr . i have a 95 Camaro 3.4l sock every thing but the flow master. o and whee can i buy it would help a lot thanks for any info
Old Mar 27, 2012 | 07:28 PM
BasicConcepts's Avatar
Technical User
youll only find it in a junkyard it really has no name either if thats leaking your rpms would jump to around 2500-3000 thats a huge vac leak
Old Mar 27, 2012 | 07:57 PM
DemonDark's Avatar
ts sucking air in thats for sure its split right up the big hole not sure if that would explain lower mpg and a little mis or the hesitation when i take off some times feels like im losing power but i can hear the hiss and if i even wiggle it the rpms go up and down
forgot to say thanks for the info
Old Mar 28, 2012 | 06:12 PM
Old Mar 29, 2012 | 12:03 PM
DemonDark's Avatar
well thanks for info i ordered it will get it Friday and wil let you guys kno if i has the piece so wish me luck and thanks o on a side not i replaced an o2 censer and did the map or mas cleaning got a new air filter to and still have that slight mis haven't run it hard yet to e if i still get the hesitation but seams like the power is there again. any other idea thanks agin
Old Mar 29, 2012 | 05:39 PM
Technical User
do you have a check engine light on?
Old Mar 29, 2012 | 09:02 PM
DemonDark's Avatar
no light had to clean the egr pipe out to fix egr code a while back had a new cat last year it puzzles me
Old Mar 29, 2012 | 09:53 PM
how old are the plug wires?
Old Mar 30, 2012 | 03:31 AM
DemonDark's Avatar
less than a year plugs to even changed the fuel filter once but because gas hand doesn't work right i did run it empty once maybe i sucked some stuff in it but its always had the little mis
Old Mar 30, 2012 | 10:38 AM
Technical User
I'd do plugs and wires and see how she does from there
