Help weird electrical issue.
Old May 9, 2016 | 05:48 AM
BrokeAgain91's Avatar
Default Help weird electrical issue.
So the other day my camaro started blowing the turn signal fuse. I started doing some research and realised its a common thing with these cars when the reverse light sensor kicks on. But my car only blows fuses when the car is sitting still. So i checked all the bulbs and sockets. come to find out the front turn signal sockets were burnt and corroded so i wired up some new ones and cut out the halo lights that were rigged into the day time running lights bam it quit poping the turn signal fuse. Whats really odd though is on the driver side the corner marker lights in the turn signal light housing and tail light housing dont work now along with the reverse lights. Does any one have any suggestions im pretty stumped now on whats going on.
Old May 9, 2016 | 11:22 AM
95 camaro 406's Avatar
check all the wireing ,you said some lights were hooked up to others wireing ,sounds like someone played with the wireing at one time
Old May 9, 2016 | 12:45 PM
Ive gone threw all the wiring and replaced every bulb socket that was burnt or coroded as well. Whats the odds of this being a drl module issues?
Old May 9, 2016 | 04:08 PM
sounds like you got the wires for the blinker hooked to the side markers, side marker wires must be hooked to the blinker, you may have the hot wire on one hooked to ground or the blinker wire is hooked to side marker and both parking light for blinker light and side marker are on the blinker socket.
Old May 11, 2016 | 02:40 PM
So just a small update i did the DRL by pass the car stopped burning out bulbs. I made it two days without blowing a fuse. Today i was sitting in tacobells drive threw and it blew the fuse and wouldnt stop blowing them. So i tried again two hours later and sure enough it accpeted the fuse and everythings working fine.... im so confused now. Could it be the reverse light switch?;/
Old May 12, 2016 | 10:34 AM
sure sounds like a wire shorting to ground. intermittent issues are a pita.
Old Sep 10, 2017 | 03:50 PM
4thGen's Avatar
Default WeirdWire
I have a '99... all of my lights work fine, minus the hazards... 3/4 of the hazard lights work.... replaced to pigtails and bulbs... still no idea... but, the thing is, the ONE that the hazard light doesn't work on, the blinker light DOES work... stumped.
djsquare1
Aug 6, 2014 08:32 AM
GoofieJ21
Dec 9, 2010 08:00 PM
BigJims70
May 4, 2010 02:29 AM
traumadog
Mar 30, 2009 10:38 AM
Lenn
Oct 6, 2008 07:49 PM
