HELP stuck putting it back. Where does the purge sensor bracket go?
Ok, So I have put back my first Camaro. You guys helped me so much my first motor job was heads in my 96 3800 v6 series II from the top...So, I took pix I did all that everyone said, but...
I have this bracket that has the canister purge solenoid and the caniter purge valve on it. It is a long piece of metal, black, and the purge items are attached to it...But...In the pix the alternator is in front of it I guess and I have no idea where it goes? ANYONE with a 3800 who can point me in the right direction, I have everything back together but this? THANKS! I need a picture or specific info on the correct location of the bracket...
You guys are great!
You guys are great!
![Icon Bike](https://camaroforums.com/forum/images/smilies/icon_bike.gif)
It is behind the alt. If the whole piece is assembled then line it up with the alt and it should be easy to see where it goes. One of pieces has an entry for bolt that goes the alt. Il try to post a pic later.
heartbeat_jr
10-12-2013 07:28 PM
78LT350
05-06-2010 09:16 PM
