Help PLEASE!!!
Old Sep 28, 2009 | 12:19 PM
Laura's Avatar
Default Help PLEASE!!!
Hi - I bought my 3rd 2000 Camaro this weekend. I've owned 2 in the past and never had this problem. I'm thinking it's a short somewhere (but where)? Sometimes the power windows and the radio goes off at the same time, I hit the power locks a few times and the go back on. I also checked the fuses...they seem fine. Any suggestions?
Old Sep 28, 2009 | 02:59 PM
There is a rubber boot between the front of the door and the door hinge pillar that has wiring to the door running inside it. Next time the car acts up, try giving that boot a good wiggle and see if anything changes. If it works, you have a broken wire (not uncommon to happen). I don't know why the radio wiring would be affected if that is the issue, but it's somewhere to start looking anyway.
Old Sep 28, 2009 | 04:55 PM
Laura's Avatar
I'll give a try thanks!
Old Sep 28, 2009 | 06:09 PM
GMDCAMARO's Avatar
I've had this issue for a little over 2 years now. I haven't really looked into it. I just wait patiently for her to come back to life.
If you do find a cure, be sure to share.
Old Sep 29, 2009 | 10:56 AM
javb_vb's Avatar
I had this issue couple months ago, the radio an the power windows just go off, one day the car didn't start I had to change de Ingnition switch since that time I dont' have this issue, I'm not sure if that was my problem but it works
Old Sep 29, 2009 | 11:10 AM
there is a 35amp breaker that is for these in the power box under the hood. could be your window motor is going and drawing to much juice thowing the breaker. could also be a bad breaker.
Old Sep 30, 2009 | 02:59 PM
Laura's Avatar
I haven't had a problem with it since the weekend, wish me luck! Thanks for the advice! Do you happen to know a good cleaner for the front head light? They are really aged and dull looking.
Old Sep 30, 2009 | 03:31 PM
DC2250's Avatar
several of them at the local auto parts store, name brand is up to you .
