Help with Ignition coil testing
As far as mine goes it was either shutting itself off ( fuel pump) or when it got hot it was running fine till shut off but didn't wanna get started again either due to some sorta shut off or heat causing pump motor to expand or something not sure but it was very unpredictable but got worse and worse.
So today I bought a new ignition coil, just one, and I just started replacing the old ones one by one with the new one and made no difference in the problem.. The last thing I can think of is the ICM.. Like I stated before the spark plugs, wires, and now the coils have been tested so just leaves ICM right?
