Help! I need to know a bolt size
Old Jul 18, 2019 | 08:30 PM
Mccxvi1216's Avatar
Default Help! I need to know a bolt size
99 3.8V6 series 2 upper intake, on the back side where the vacuum line from the break booster I need to know the bolt size that holds the vacuum line. I’ve already got the top intake on and can’t quite tell the size or if it’s tapper bolt or not. -Thanks-
Old Jul 18, 2019 | 09:11 PM
peterpar's Avatar
If I'm understanding you correctly, you're wanting the bolt size holding the vacuum booster flange to the intake? If so, the parts manual states that they are M6x1x10. I've attached an illustration form the parts manual that may help identify the part.
File Type: pdf
juice+
Oct 14, 2012 08:13 AM
Ishmael
Mar 5, 2012 04:37 PM
yam700
Apr 2, 2011 02:38 PM
thebandit110
Mar 17, 2008 09:47 PM
lighter
Nov 8, 2006 05:51 PM
