Help! I have a 94 firebird wire harness trying to make fit on a 96 camaro, possible?
Old Nov 18, 2013 | 07:50 PM
Dz28's Avatar
Default Help! I have a 94 firebird wire harness trying to make fit on a 96 camaro, possible?
Hello everyone, iam still new to this and this seems like the best place to ask questions on camaros. My 96 harness got burned in areas from my headers. So i bought a 94 firebird parts car well i should of done some research cuz iam missing plug c105. Does anyone have some advice or came across this problem yet.
Old Nov 19, 2013 | 12:35 AM
fbodyrs96's Avatar
94 is obdI and 96 obdII, harness will be different.
Old Nov 19, 2013 | 10:55 AM
Much easier to repair your burn harness then to reto the 94 into the 96.
We are talking Lt1?
Old Nov 19, 2013 | 03:06 PM
Dz28's Avatar
Yes lt1, ive been doin searching around and have found that a couple people have made this work iam jus not to familiar with witch wires to tap into. So how does the obd1 and 2 effect at the end result?
Old Nov 19, 2013 | 05:05 PM
You are going to have to figure all that out. You can make anything work you can also fix anything. IMO fixing you old is going to be a lot easier then retroing a different harness. There are no books on how to put a 94 harness in a 96. There are books on how to repair your 96 harness, its call a repair manual. It tells you where everything goes, all you need a some good wire , solder and shink fit. Manual are free for download in the manual section.
jenz
Jan 26, 2015 09:28 AM
cannibal440
Nov 9, 2009 12:52 PM
BP80Z28
70-81 V8 Tech
Oct 22, 2009 07:00 PM
94z28chevy
82-92 V8 Tech
Apr 12, 2008 12:30 AM
