HELP! Can't keep car started
1994 3.4 Camaro
A few days ago I was in a parking lot going to move my car from the spaces to a gas pump when she died out on me. I got in, started it, went into reverse and got about halfway out of the space when it died. I was low but I didn't think I was THAT low. Well I threw a couple gallons in so I could drive it to the pump and fill her up but as soon as she started she died again. Did this a few times and she kept dying within a few seconds. I left it sit over night, came back and she fired right up. I cruised around the lot a few times to make sure everything was copasthetic and she drove fine. I got out on the main road and when I went to speed up she died again. Waited another day...same thing happened. Got about a quarter mile before she died. She will only start if she sits for a while. Seems like the longer she sits, the longer she runs.
I can hear the fuel pump priming, I don't see any leaks or anywhere furl could leak from, and I checked the fuel filter for clogs.
^^^ yep sounds like a failing fuel pump. test fuel pressure to confirm. for directions to test fuel pressure go here and click number 33 4th Gen LT1 F-Body Tech Aids
change fuel pump, go here and click number 9 https://camaroforums.com/forum/93-02...62/#post557634
on our Z, 1/4 tank on the gauge is actually empty but the needle does go to E when the car is off
F is 3/4 and, pegged all the way past F is actually full
I know I'm super freaking late, but my 96 did the same at one point, I replaced IAC Valve, and the PCV Valve, and the Air Filter and she fired up and ran great no problems after I then continued to replace spark plugs and wires, everything seems to be great (:
