Help! asf off and abs inhop i cant figure it out!
I had these two lights come on about two days after I got my car and I scanned it at work
the code came up c0045 which says rear left wheel sensor. So I replaced it and lights went off, then I put a lowering kit on, eibach pro kit, and the lights came back on. So I warrantied the sensor two days ago but light is still on!? I pulled the others side and cleaned it and cleaned all connections, the one behind the back seat and even cleaned the ground in the engine compartment.
If anyone has any ideas it would really help.
I really wanna get this fixed; after 50 mph my brakes are sketchy
thanks
thanks
Meh, my "ABS INOP" light has been on since buying the car. A number of things could be setting it off. Unless u drive this car year round and in bad weather i wouldnt worry about it. Im getting the ABS delete kit and just tearing it out to clean up the engine bay. Of course if this is ur DD i would want to diagnose and fix the issue.
