Help!!!!!!
Old May 11, 2012 | 08:44 AM
bushwhacker86's Avatar
Question Help!!!!!!
i hope this isnt a repeat! I Have a 98 Camaro V6 3.8L with a brand new engine,spark plugs/wires, and rad. I have gone through 2 PCMs due to heavy rain. I know its located under the windshield but shouldn't there be something to prevent this from happening every time it rains? And also, my car has been making a grinding noise when I was trying to crank it...is that the starter or something else? I really don't want to get rid of this car, but I feel like its falling apart...again. Thanks for the help!
p.s. it sounds like it wants to turn over but doesn't complete the cycle
Old May 11, 2012 | 10:01 AM
You should be able to spray water on the PCM and not damage it. You have to remember just because the PCM is failing during the rain does not mean the problem is with the PCM. It is a lot more likely the PCM is getting fried by item that is failing during the rain. A bad wiring harness that shorts or a something that is causing a voltage spike. Bad alternator or any type of capacitor comes to mind.
The grind is most likely a starter to flywheel alignment issue fixed with a small shim. If it has been going on for awhile the flywheel could be shot.
Did you just buy the car or are both these issue on going? If you just bought the car and the motor was installed by some that did not know or care what he was doing the problems can be 10X harder to find. Finding known common wear issues is one thing. Trying to figure out what dumb mistake a clueless person did is a whole other level of trouble shooting.
Old May 14, 2012 | 08:17 AM
Thank you so much...last time the dealership took the new pcm out and about an inch of water drained out of it. Ialso had a feeling that it was the starter making that awful noise. I just dont know if I should sink anymore $$ into this car.
Old May 14, 2012 | 09:20 AM
i have the water issue in my 93. not sure how the water gets there. i covered the unit using a glad freezer bag. seems to have worked.
Old May 15, 2012 | 08:01 AM
Turns out the re-man pcm doesnt have a seal on it to keep water out. Had to get an OEM from the dealership
Old May 15, 2012 | 09:21 AM
1augapfel's Avatar
Man, that sucks!
Old May 16, 2012 | 01:20 PM
Massey's Avatar
I was gonna say the water seal but it looks as you already figgered it out.
Massey
