Help
Old Jan 18, 2011 | 02:26 AM
ampprc's Avatar
Default Help
just put in a new fuel pump racetronix 255. there was a 255 already in it. now the car only starts and will idle rough and then die after 15 sec. has new wires, plugs, and opti. its getting spark fuel presure is at 45 psi when running.
Old Jan 18, 2011 | 05:31 AM
did you replace the fuel filter?
Old Jan 18, 2011 | 10:35 AM
Massey's Avatar
^^+1 and is there any codes?
Massey
Old Jan 18, 2011 | 12:51 PM
ampprc's Avatar
I have have put a new fuel filter and I have taken all the gas out of the gas tank and put new gas I'n it
Old Jan 18, 2011 | 01:24 PM
Massey's Avatar
Codes?
Is your check engine light on?
Massey
Old Jan 18, 2011 | 02:25 PM
ampprc's Avatar
Originally Posted by Massey
Codes?
Massey
no codes. check engine light is off
Old Jan 18, 2011 | 02:30 PM
have you had the injectors cleaned and flow tested yet. not very expensive. mine cost like 30 bucks counting shipping, im in the middle of nowhere. anyways had them back in 4 days. have you told us all of whats been done and what new parts you have installed?
Old Jan 18, 2011 | 02:46 PM
ampprc's Avatar
haven't had the injectors cleaned and flow tested. when the car starts i spayed some starting fluid in it to see if it would make the engine rev. it just dies.
Old Jan 18, 2011 | 02:54 PM
well then its a spark problem. i would have the coil and ignition module tested. it may be that your getting good spark at first then it drops or could just be weak spark. is your tach working?
Old Jan 18, 2011 | 03:02 PM
ampprc's Avatar
how can u test the coil and ignition module.
