help!
The 4th gen Camaro (93-02) is not a good beginner car. The engine replacment is far from easy.
agree with rfx except if its in really good shape id go to 900, if your heart is set on doing this pick up a facrory service manual for your year and model. woh this set is a good deal.
http://compare.ebay.com/like/4001807...=263602_304662
What needs to be done all depends on where the block is cracked, and whether it's structural and in a critical area, or just a crack with a small leak.
Cracks/breaks in cast iron blocks can be welded.
As I said, it depends on what kind of crack, where the crack is located, and what caused the crack in the first place. Do you have those answers?
loophole?
