help
got this from shbox. its a good place for a bunch of stuff.
http://shbox.com/1/4th_gen_tech1.html
Remove the radiator cover. (three 8mm bolts on top)
http://shbox.com/ci/ci460.jpg
Disconnect and remove fan assembly. The fan assembly is hooked to the radiator side tanks and can be lifted up to unhook it and then lowered out the bottom.
Disconnect the transmission oil cooler lines from the radiator (if applicable). (1/2" fitting - flare nut wrench recommended) A small amount of transmission fluid will come out. I used a couple of plastic plugs I had to cork the transmission line fittings in the radiator, so that it would not drip as I removed the radiator.
Unplug low coolant sensor connector.
http://shbox.com/1/low_coolant.jpg
Release a/c condensor line from guide on bottom passenger side of radiator tank.
http://shbox.com/ci/ac_hose.jpg
Lift up on a/c condensor to unhook it from the radiator. Remove the radiator. Try not to damage the fins.
