HELP!!
Old Jun 28, 2008 | 10:20 PM
DAVIDP2000's Avatar
Default HELP!!
Hello I have a 95 camaro z28 5.7 Lt1 3 Days ago i was driving about 45 mph and the car just stalled out after drifting to the side i started the car and drove home with no problems. I thought i should change the fuel filter just in case it was clogged. Today i did my rear brakes while test driving it stalled out again for no apparent reason but started right back up and ran great. Has anyone else had this problem? Could it be my fuel pump? HELP PLEASE!
Old Jun 28, 2008 | 11:15 PM
95slvrZ28's Avatar
Default RE: HELP!!
Is the car running ok otherwise? Is the SES light lit or blinking? Any other indication of any sort of problem?
Old Jun 28, 2008 | 11:24 PM
DAVIDP2000's Avatar
Default RE: HELP!!
NO Lights. I just got back from the store drove about 6 miles and it ran great. I dont get it can a faulty fuel pump act up like this?
Old Jun 28, 2008 | 11:27 PM
DAVIDP2000's Avatar
Default RE: HELP!!
Ses is security system light? Thanks for the reply fuzzy
Old Jun 29, 2008 | 12:48 PM
lt4weeda's Avatar
Default RE: HELP!!
when my car did something similar to thi but i wasnt moving, i was stuck in traffic and the constant start stop cause my car to heat up and the coil stopped putting out spark, but if your moving i would think it would be a fuel problem, try running some injector cleaner also id check and see if i had any pigtail wires that were loose or any bare wires that could touch and short something out
