Headlight covers
It will dim your lights. The reason I took mine off was the Tennessee state trooper. I put some clear ones on from Summit and like the look. Around fifty bucks. You see the brackets some and they don't fit perfectly.
I have a set of smoked and clear lenses. I usually drive around during the day so I keep the smoked ones on...but if I drive at night I just switch to the clear ones. The smoked ones greatly reduce the light projected. U can drive with the brights on...but it still is as bright as low beams with clear lenses. about $50 for each set. They use the same brackets if you buy the same brand.
Do you have HID's?
Do you have HID's?
haha alright thanks. And no i dont have HIDs. So smoked headlights is usually just a day thing then? Im going for the black out look. Ive got some black tail lights on the way. And im looking for some black rims. How would black C6 rims??
