Header Install prep and precautions.
Old Apr 28, 2011 | 03:12 PM
Roachz28's Avatar
Default Header Install prep and precautions.
I know these questions have been answered in other threads, but I always seem lucky enough to find something that gives me doubt. I am gonna be installing pacesetters with a tsp off road ypipe, I have rear o2 sims and o2 ext for the front. now if im not mistaken the '02 ls1 does not have egr system but it does have the AIR system? if i remove the AIR system is my car gonna throw a code and do I need any special blockers for plugging hoses or such? also should I do pulleys during this or are those not all that difficult to do otherwise? what pulley mod is best?
Old Apr 28, 2011 | 03:15 PM
Failed Devices's Avatar
Old Apr 28, 2011 | 03:38 PM
je$$up97's Avatar
I did a set of march pulleys but I took them off. It seemed to put too much strain on my alternator and the crank pulley wasn't very well balanced.
If your not running a lot of electronics and no AC I would say go ahead, but otherwise I didn't find it a good mod IMO.
Old Apr 28, 2011 | 04:17 PM
Roachz28's Avatar
yeah it wouldnt be a good idea me either, I have an amp and subs and sometimes run the ac when the ball and chain is in the car with me. Im just looking for a replacement cuz I think my stock ones are goin bad.
Failed: thanks for the threads. Are those two different air systems though?
Old Apr 28, 2011 | 05:38 PM
libertyforall1776's Avatar
Header install time is a great time to replace your engine mounts -- if you have a lot of miles, they may be saggy and could result in floorboard noises after header install...
Old Apr 30, 2011 | 11:17 PM
Roachz28's Avatar
yeah I could do that thanks Liberty.do I need to get block off plates if I get headers without air fittings?
Old Apr 30, 2011 | 11:22 PM
Roachz28's Avatar
Also I am worried my car is gonna smoke/smell if I remove cats and remove the AIR system. I will be using o2 sims for the rear o2 sensors. I wont be able to get a tune until the fall.
Old May 2, 2011 | 12:21 PM
je$$up97's Avatar
unless you have a hole in your exhaust and in your floorboard i don't think you'll notice the smell.
Old May 3, 2011 | 12:47 PM
I would not cat-delete -- the rasp is not worth it to me, high flow cats will be the better choice, IMHO. Get a cutout installed with an electronic valve, then you can adjust the sound at will from the driver seat! Also, removing the AIR system should not be a big deal, yes you need blockoff plates.
Here's a guide:
AIR Removal with PICS! - LS1TECH
Old May 3, 2011 | 05:36 PM
Roachz28's Avatar
Thanks lib, Yeah i examined my air system i saw where i would block it. The only reason I dont want cats is cuz I am cheap lol. but i will prolly spend the extra $100 for cats.
RPDRed6
Feb 4, 2014 07:26 PM
CamaroDreamer
LS Series Tech
18
Nov 10, 2011 09:07 AM
CamaroDreamer
Mid West
Oct 31, 2011 12:22 AM
MudWild680
Feb 18, 2009 06:53 PM
gotalcoholmanup
Apr 3, 2006 12:52 AM
