head or intake gasket
Old Dec 26, 2011 | 04:55 PM
Originally Posted by 98stuntin
it was water on the oil dipstick so he said its possible
That's not a good sign, it means coolant is down in the oil pan. So then yes, you are taking a chance that the bearings could have been damaged, because water/coolant sinks to the bottom of the oil pan (oil floats), and the oil pump sucks off the bottom of the pan.
Old Dec 26, 2011 | 06:00 PM
If your oil looks like milk shake and you drove it that way you should just start looking for a motor. I have seen a lot of cars with one week old headgasket and bad bearings.
Old Dec 27, 2011 | 09:30 PM
Azariah's Avatar
I am also replacing a head gasket on my 02' 3800. I have it all stripped down to the block I was wondering if there are any special procedures I should go through (and how to go about them) such as measuring the heads to make sure they are not warped or anything else like that??? I also noticed rust working its way up the mating surface on the block on cyclinders 3 and 4 are there any special proceedures to take or am I just pretty much screwed???
Also on cyclinders 4 and 6 the exhaust valves are whiter than the other 4 is this an indication of a bad head gasket??? I originally thought the head gasket was bad but after tearing the whole engine down I see no sign other than white valves on 4 and 6.
Any advice is greatly appreciated, I would love to get this thing back together.
Thanks again
Old Dec 27, 2011 | 09:47 PM
Thanks again
Start your own thread don't hijack some elses.
Old Dec 28, 2011 | 01:39 AM
RFxCamaro's Avatar
You will need a torque angler for these heads.
Old Dec 28, 2011 | 05:57 AM
you can replace or rebuild the motor now or when the bearings go out. listen to gorn.
electric avenue 6
Mar 18, 2014 03:36 PM
Cody's z28
Nov 7, 2012 10:28 PM
borjawil
Mar 6, 2012 04:29 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
dcanada53
Mar 5, 2008 06:01 PM
