Hawk HPS pads MUCH better than stockers
Old Feb 18, 2012 | 07:20 PM
libertyforall1776's Avatar
Thumbs up Hawk HPS pads MUCH better than stockers
So I just replaced my rear brake pads with Hawk HPS pads in my RS -- wow what a difference -- in just the hard stopping burnishing process from 45 mph hard braking they really bite hard! Can't wait till my fronts need replacing! Whatever was on there was OEM probably originals, I bought the car used.
Note that this is without flushing the brake fluid, which I plan to do, but along with adding some stainless steel brake lines...
Anyone still on OEM pads, I highly recommend giving these a try, rpmspeed.com has a good price, btw.
Old Feb 19, 2012 | 12:32 AM
Did you replace the rotors too?
Old Feb 19, 2012 | 12:35 AM
^ Same rotors -- still within spec -- vernier caliper measured.
Old Feb 19, 2012 | 12:49 AM
Took sandpaper to them at least to remove the glazing, so the new pads will "break in"?
Old Feb 19, 2012 | 09:52 AM
androzer's Avatar
I have Z28 94 and my rear brakes are drums :-) and I used organic pads:-)
Old Feb 19, 2012 | 10:19 AM
iLL95's Avatar
I Like to Party
Super Member
A smile? I hate my drum brakes.. look crappy
Old Feb 19, 2012 | 11:53 AM
NorthernCrew454's Avatar
you like asbestos?? lol
Old Feb 20, 2012 | 12:36 PM
Wire brushed them, and followed Hawk's burnishing instructions:
Bed-In Instructions
Old Feb 20, 2012 | 12:37 PM
Lightbulb
So swap upgrade them -- the process is not terrible -- I did it on my old '95 3.4L...
Old Feb 20, 2012 | 02:08 PM
Bed-In Instructions
A wire brush won't take the glazing off. When reusing rotors, you want to sand the surface to remove all the glaze (shine). Without deglazing, your brakes aren't going to work to their fullest potential. Think of it being similar to installing new piston rings on glazed cylinder walls. You wouldn't do that either.
