Having some 3.8 problems! HELP!
We just got done fixing a bad intake gasket leak and now its running pretty rough and is also very doggy no matter what temp its!Its kind of hard to explian but it want to surge forward with every stroke of the engine at low RPMs and at idle it shakes the hole car! Any ideas would be great! Oh and by the way I am a newby so I need a little help with some the short terms!
To make sure there is a vacuum leak you are going to have to use a vacuum gauge to read if anything is off. After that keep spraying starting fluid til the rpms go up. If you still can't dnd It thej get some soap and water and put all along the intake. Turn the car own and look for bubbles. It takes a while but trust me if there is a leak then starting fluid will make it rev up. It took me a whole day to find mine.
