H22 Honda Vs LT1 Camaro
Old 05-05-2008, 11:36 AM
Spartan66's Avatar
Default RE: H22 Honda Vs LT1 Camaro
doubt i will but ill keep you posted. If we do it probably wont be a "legal" or sanctioned race...the first from point a to b race probably.
  #32
Old 05-05-2008, 11:23 PM
kaoss_11's Avatar
ORIGINAL: SpecterGT260
both the montes and impalas had an iron headed LT1 for a while
I knew impalas but when did the montes
  #33
Old 05-05-2008, 11:51 PM
Spartan66's Avatar
Monte Carlos never had an LT1 stock. If your talking about a 5th gen the biggest engine they had was a 3.8L and the biggest engine in the 6th gen was a 5.3LLS4. However the 4th gen Montes had 5.7L LM1 and oddly enough a diesel 5.7LLF9 which was an olds engine that lasted from 78 to 85.
  #34
Old 05-06-2008, 12:08 AM
Blade's Avatar
June 2007 ROTM
its gotta a auto stick in it, and he might be able to drive.
  #35
Old 05-06-2008, 12:34 AM
Spartan66's Avatar
ORIGINAL: Blade
What?
  #36
Old 05-06-2008, 12:37 AM
Blade's Avatar
June 2007 ROTM
prelude's have the auto stick in them
  #37
Old 05-06-2008, 03:08 AM
Spartan66's Avatar
auto stick? as in an automatic transmission?
  #38
Old 05-06-2008, 03:14 AM
Blade's Avatar
June 2007 ROTM
autostick is the transmission that u shift gears with out a clutch similar to a auto
  #39
Old 05-06-2008, 09:28 AM
LT1RUNNER's Avatar
Spec you're usually pretty knowledgable about most subjects but I've never known a Monte to have a LT1.
  #40
Old 05-06-2008, 10:27 AM
SpecterGT260's Avatar
Ninja Administrator
are you sure? i thought the older ones had them and then they went to v6 only the same time the impalas did [&:]
Quick Reply: H22 Honda Vs LT1 Camaro
